Sony Playstation PS2, PS3
Moderators: Sparco, Jaanus, Strike, Erki, Sport, Krusa, Heix
Post Reply
Heix
Contact:
Post by Heix »
Kurb uudis PS@Home ootajatele.
Sony otsustas kinnise Beta testimise edasi lükata 2008 aasta sügisesse mis võiks tähendada, et enne 2009 meie silmad full versiooni ei näe :(
ImageCitroën Sport
Burns
Post by Burns »
Kahju tundus huvitav asi tulevat
Diagnoos- Rallisõltlane
annu333
Post by annu333 »
Sama siin... Mida nad siis seda nii reklaamivad... ajab ikka närvi küll... Seal oleks kohe oma kommuuni teind :D
adi007
Post by adi007 »
Kas keegi oskab subtiitreid panna filmile?
Krusa
Contact:
Post by Krusa »
Selgita natu lähemalt?
adi007
Post by adi007 »
Nagu mälupulgaga filmi vaadata ja siis nagu lisada subtiitreid filmile.
Krusa
Contact:
Post by Krusa »
Mis formaadis failid?
Heix
Contact:
Post by Heix »
Ühesõnaqa niipalju kui mina aru sain siis ala .sub ja .srt faile ps3 ei toeta.
On olemas alternatiiv et neid toetama panna, kuid seda peab siis ala iga filmi jaoks eraldi tegema.
Kui huvi siis võid proovida kas allolev lahendus ka töötab ;)
What you need to do is download avisynth and vsfilter.
avisynth from http://sourceforge.net/project/showfile ... _id=366702
vsfilter from http://downloads.sourceforge.net/gulive ... 0051125.7z?
modtime=1132957360&;big_mirror=0
Once you have downloaded avisynth and copied the vsfilter.dll to the plugins directory of the avisynth install you need to create a text file.
For instance - if you wanted to subtitle star wars you would do the following.
create a text file called starwars.avs.
in the text file add the following two lines.
AVISource("C:\Videos\starwars.avi" )
TextSub("C:\Videos\starwars.srt" )
Save the file. Now using PS3 Video 9 point at the starwars.avs file rather than starwars.avi file and hey presto - you now have a movie with subtitles.
The beauty of avisynth is that whatever video format windows media players supports will work with avisynth and ps3 video 9. So if you have a file format that isn't supported by ps3 video 9 but does work on windows media player just create a little script and use the avs file instead.
Üks variant on veel, et liidad subtiitri ise juba filmile sisse.
http://www.calcitapp.com/AVIAddXSubs.php
ImageCitroën Sport
rally
Has thanked: 1
Post by rally »
Kas keegi ei tea kas nüüd tuleva aasta alguses mingeid mänge ps2 ka on , midagi ralli või vormeli teemalist,hetkel ei hakka ps3 ka ostma kuigi graafika tal ju jube hea.
Rallime Mönuga !
treik
Post by treik »
rally wrote:Kas keegi ei tea kas nüüd tuleva aasta alguses mingeid mänge ps2 ka on , midagi ralli või vormeli teemalist,hetkel ei hakka ps3 ka ostma kuigi graafika tal ju jube hea.
Kas Sul WRC Evolved on juba läbi mängitud ? Kui ei siis muretse, PS2 le on see parim rally mäng+ saad ka meie hooajast osa võtta kui huvi on.
treik
Post by treik »
Kui kellegi vedeleb ülearune PS2-e pult(juhtmega), siis oleksin huvitatud. See PS1-e oma küll töötab, aga läheb vahepeal lolliks ja ei allu korraldustele.
Sander Gryn
Post by Sander Gryn »
lausa 2 tükki vedeleb :D
Peugeot Sport
www.peugeot-sport.com Burn in Hell f.....g Peugeot, no more!!
Burns
Post by Burns »
Tervitus.
Homme siis see päev kui saab endale alla laadida Playstation Home. Tundub päris asjalik asi tulevat.
http://blog.us.playstation.com/
Burns
Post by Burns »
Siin siis kodulehekülg: http://www.playstationhome.com
Burns
Post by Burns »
Äkki keegi viitsib siin sellest ka natuke kirjutada, kui on endale alla laadinud (kuda on jne...). Ma pole enda PS3 garantiist veel kätte saanud. Täna helistati, et viga on parandamatu ja nüüd nad organiseerivad mulle uue PS3.
treik
Post by treik »
Burns wrote:Äkki keegi viitsib siin sellest ka natuke kirjutada, kui on endale alla laadinud (kuda on jne...). Ma pole enda PS3 garantiist veel kätte saanud. Täna helistati, et viga on parandamatu ja nüüd nad organiseerivad mulle uue PS3.
Milles seisnes PS-i probleem ?
Burns
Post by Burns »
Kle käima pannes ei visanud enam seda pilti ette, kus on kasutajad (kus ma alguses ennast sisse login)
Burns
Post by Burns »
Tere!
Laadisin endale selle Home´i alla, sain ilusa popi korteri ja puha aga mul selline küsimus. Kui ma tahan endale mingit nänni saada (mida iganes), kas kõik on ainult raha eest? Ja kas ma saan peale kodukandi ka kuskil ringi käia?
Muidu tundub päris lahe asi olevat :)
Heix
Contact:
Post by Heix »
Burns wrote:Tere!
Minuteada on ainult osa asju tasulised. Kuskilt kuulsin et sinu mängudega teenitud trofeed annavad sulle raha home-s ;)
Ise olen ainult korra sinna sisse saanud ja siis ei olnud eriti ka aega ringi kolada :S Ülejäänud korrad on sisselogimisel erroreid lajatanud.
ImageCitroën Sport
Burns
Post by Burns »
Heix wrote:
Burns wrote:Tere!
Ma ka eile kolasin veits ringi aga ei leidnud kohta kus saaks mängida jne... Aga eks kolmapäeval vaba päev, siis uurin rohkem. Nõme oleks see, kui ma peaksin iga asja eest maksma, kui tahan midagi, see ikka virtuaal maailm :)
Post Reply
