Rally Sweden shakedown ja eelvaade
Reactions: 6
Re: Rally Sweden shakedown ja eelvaade
Laupäev on tõesti hetkel kõige kahtlasem, reedesed katsed on põhja pool ning nendega peaks okei olema ja pühapäevani on nii või naa rohkem aega, et selleks ajaks peaks ära külmetama.
Paari tunni pärast peaks recce algama ning eks kuuleb/näeb päeva käigus mis seisus katsed on.
Tänane ennustus ka bluufordi poolt (teda usaldan kõige rohkem)
Weather forcats is still good, today is the last day for plus degrees and not everywhere. Latest models are predicting light snowfall tonight and there might be proper snowstorm during the rally. So, those who plan many stages, be careful, roads might be slower than you expect. Temperature on Friday stages drops to -3..-4 in next 18 hours and night befoe the stages, it should drop to -5.. -6 degrees, that is more than enough to make it solid as rock. If the model predicted snowstorm arrives, then top runners will be in major trouble.
Reactions: 6
Reactions: 12
Viimased ennustused nàitavad, et lund ei tule peaaegu ùldse.
Reactions: 6
Colin Clark täna katsetelt periscope kaudu ülevaateid tegemas, tasub tema twitteril silma peal hoida
https://twitter.com/voiceofrally/status ... 6606289920
Päris jube seis ikka
Ja juba juhtub asju reccel
Reports from recce say Fredrik Åhlin has beached his recce car in the ditch. It's slippy, let's consider that as a positive! #RallySweden
Powrót Roberta ‏@powrotroberta 16m16 minutes ago
On our way to @RallySweden - 80 km from Karlstad we have such road conditions. And we are happy about it! :)
mainsail
Postitus Postitas mainsail »
Vahula kirjutas:Pilt
See on hea pilt,hakkame ka just laeva peale sättima :lol:
https://twitter.com/voiceofrally/status ... 5581698049
Colin Clark
‏@voiceofrally
It's snowing on the Fredriksburg stage @RallySweden! A few hours of this and we'll be sorted - almost!!!
C. Clark rõõmustab lörtsi üle natukene liiga palju viimastel päevadel. Aga noh, kiidan optimismi.
raulito
Postitus Postitas raulito »
-huviline2- kirjutas:C. Clark rõõmustab lörtsi üle natukene liiga palju viimastel päevadel. Aga noh, kiidan optimismi.
Meist lõunapool elavatele on juba lörtsisadu sellise tähendusega et edasi sõita enam keegi ei oska. Ilmselt selles asi ongi.
Reactions: 6
Sain ka uudiseid Rootsist koha pealt et pidi päris hästi hetkel tulema.
Reactions: 51
Pärna ja Aaseni auto
raulito
Maarendi Mini väljanägemise kohta pole mingit infi?
rally11
Postitus Postitas rally11 »
Reactions: 6
Ma sinu lingis ei näe mis ta ütleb aga ma arvan et sa mõtled seda https://twitter.com/rallyinguk/status/6 ... 5659449345
Pole mees üldse rahul, ega katse pilte vaadates tekib endal sama küsimus
Reactions: 6
Reactions: 12
Tõotab tulla väga segane ralli. Kui see tsiatsungelmaa ära külmub siis vast saab ikka katsed ära sõidetud.
Sügavad rööpad, külmunud kruus mille peal lastakse piikrehviga...läheb väga huvitavaks, eriti Ogieril kes esimesena peale läheb.
Reactions: 6
Eks Ogier sellepärast ka nii sõnakas on
Reactions: 6
https://translate.google.co.nz/translat ... edit-text=
FIA boss: "We are running as planned"
Rally
International Automobile Federation's Rally Manager Jarmo Mahonen has a clear message despite drivers' complaints about the special stages and Sébastien Ogiers requirements.
Viimati muutis Vahula, 10 Veebr 2016, 19:22, muudetud 1 kord kokku.
Reactions: 6
Mahonen ütleb et ralli toimub, las Ogier vingub :P
