Re: Neste Oil Rally Finland 2014
Postitus Postitas Rebane »
WRC-2 : Tänak (2’34’2), Ketomaa (2’36’1), Al Rajhi (2’38’0), Chardonnet (2’39’6), Kikireshko (2’42’8)
Kas yle ralliraadiot netist kah kuuleb?
Ajad
Postitus Postitas ponx »
aix kirjutas:Kas yle ralliraadiot netist kah kuuleb?
Kas ralli jaoks avatakse uus kanal või mõni "vana" teeb ülekandeid?
Siin on mõned äppid.
http://yle.fi/yleisradio/faq/tekniikka/ ... uhelimeeni
Hetkel Ketomaa eetris, varsti ehk Tänak:
WRC-2 : Tänak (2’33’3), Ketomaa (2’35’1), Chardonnet (2’35’6), Brynildsen (2’37’0), Gorban (2’37’9), Al Rajhi (2’38’0), , Kruuda (2’38’7), Kikireshko (2’42’8)
soca kirjutas:
Kolin kirjutas:Neljapäevaks lubatakse kõva äikese tormi.
nii ja naa
Panustaks, et esimene katse saab ikka päris porine olema
http://www.yr.no/place/Finland/Western_ ... _hour.html
Postitus Postitas svs89 »
https://plus.wrc.com/
Live Stages
+Up to 3 hours HD live coverage per event
+Live stages featuring iconic roads and power stages
+Including live onboard- and helicopter footage
+Live commentary from experts & special guests
Live Maps
+Track the drivers on the stages during a rally
+Follow the drivers on the stages during rallies
++Get the complete event overview
+Find spectator areas, service park and refuel points
+Including Live Timing and driver information
Onboard Action
+Be thrilled by rally action from the cockpit
+Rally experience through the eyes of the drivers
+Various onboards from WRC drivers on all stages
+Select and compare drivers’ performance
+Driver-comparison mode or single driver mode
Full highlights
+Discover the full rally action from spectacular angles
+Up to 156 minutes HD video highlights per event
+26 minutes preview magazine
+3 x 26 minutes daily highlights
+52 minutes event highlights
+Instantly available after playout
Kui viplala ennustust vaadata siis hakkab täpselt enne esimest katset ja katse ajal sadama, ei imestaks üldse kui näeksime katkestatut katset.
Postitus Postitas topsu »
http://www.lightningmaps.org/realtime?lang=en
Äikesepilved liiguvad hetkel Soome kohal läänest itta. Ligikaudu tunni pärast peaksid pilved Jyväskyla kandis olema.
topsu kirjutas:http://www.lightningmaps.org/realtime?lang=en
Pigem rohkem edela-kirde suunalised
svs89 kirjutas:https://plus.wrc.com/
Live Stages
Sai ära tellitud, eks näis, kui hea on
Soomes on ikka võimas välhutamine
jliivak kirjutas:
Live Stages
Eks näis jah. Hetkel tundub huvi suur olema ja see tõmbab kindlasti rohkem rahvast ligi. Karta aga on, et kui huvi liiga suureks läheb, siis kas hakkab kinni kiiluma, või tõstavad kuu maksu...
Seinäjoe lähedal selline kaamerapilt maanteel http://liikennetilanne.liikennevirasto. ... d=C1053401
Sealt Jyvaskülasse vaid 190 km. Ja hetkel veel üle kahe tunni aega, et see pilv sinna jõuaks.
Postitus Postitas Rainy »
aix kirjutas:
jliivak kirjutas:
Live Stages
Tellisin ka ära, päris huvitav oli võrdlevaid onboarde vaadata, saab ise valida sõitjad, kellega võrrelda. Eks näis, kuidas Soome ralli ajal see töötab.
Enne, kui hakkab siis meenutame ralli klassikat https://www.youtube.com/watch?v=eiuus52__eI
Ka siis sadas vihma rallil. Ehk on see hea märk meile
Äike vaikselt läheneb Jyväskyla poole. Aga tundub kaardi järgi, et suurem pauk läheb mööda
Kolin kirjutas:Äike vaikselt läheneb Jyväskyla poole. Aga tundub kaardi järgi, et suurem pauk läheb mööda
No see äike peab ikka suure kukerpalli tegema, et Jyvaskülast mööda läheks http://www.lightningmaps.org/blitzortun ... hp?lang=en
