kiireim ring:
K. Räikkönen 1:45.108
1. kakuke - 524
2.-3. Fulber - 400
2.-3. albertz - 400
4. kosmonaut - 3
5.-20. mrali - 0
5.-20. nimh - 0
5.-20. Kolin - 0
5.-20. Optik - 0
5.-20. quattro - 0
5.-20. xaus - 0
5.-20. Frank - 0
5.-20. RudiTurbo - 0
5.-20. annmacher - 0
5.-20. j6mm15 - 0
5.-20. KAIKUL - 0
5.-20. cruiser - 0
5.-20. swensson - 0
5.-20. o0tt - 0
5.-20. XTROY - 0
5.-20. maario - 0
Aastal kaks tuhat kuuskümmend
Nüüd oleks siis õige aeg öelda et mina mõtlesin välja kakukese ennustuse. :D
Postitus Postitas mrali »
Kuda selle teise süsteemiga asi oleks kujunenud??
Postitus Postitas nimh »
Uue süsteemi järgi oleks välja tulnud selline järjestus:
(võrdse aja puhul on eespool see, kes postitas ennustuse varem)
1. kosmonaut (M. Schumacher, R. Barrichello, F.Alonso, K. Räikkonen)
1:45.537 - 0.003 = 1:45.534
2. Optik (M. Schumacher, R. Barrichello, K. Räikkönen, F. Alonso)
1:45.537 - 0 = 1:45.537
3. cruiser (M. Schumacher, R. Barrichello, K. Räikkönen, F. Alonso)
4. o0tt (M. Schumacher, K. Räikkönen, R. Barrichello, F. Alonso)
5. Frank (M. Schumacher, K. Räikkonen, R. Barrichello, J. Trulli)
1:45.544 - 0 = 1:45.544
6. maario (M. Schumacher, R. Barrichello, K. Räikkonen, J. Trulli)
7. Kolin (M. Schumacher, K. Räikkönen, R. Barrichello, J. P. Montoya)
1:45.706 - 0 = 1:45.706
8. Fulber (K. Räikkönen, M. Schumacher, R. Barrichello, J. P. Montoya)
9. mrali (M. Schumacher, R. Barrichello, F. alonso, J. Trulli)
1:45.734 - 0 = 1:45.734
10. nimh (M. Schumacher, R. Barrichello, F. Alonso, J. Trulli)
11. RudiTurbo (M. Schumacher, J. Trulli, F. Alonso, R. Barrichello)
12. xaus (M. Schumacher, R. Barrichello, J. Button, K. Räikkönen)
1:45.857 - 0 = 1:45.857
13. XTROY (M. Schumacher, K. Räikkönen, R. Barrichello, J. Button)
14. quattro (M. Schumacher, K. Räikkönen, J. Button, F. Alonso)
1:45.908 - 0 = 1:45.908
15. albertz (K. Räikkönen, J. Button, F. Alonso, M. Schumacher)
16. Erki (M. Schumacher, J. Button, J. P. Montoya, F. Alonso)
1:46.268 - 0 = 1:46.268
Sulgudes on arvesse läinud piloodid, miinusmärgi taga olev arv näitab preemiasekundituhandikke, mis saadud kiireima ringi täpse aja ennustamise eest.
Nagu näha, on seis mõnevõrra huvitavam kui vana süsteemi järgi.
Postitus Postitas cruiser »
Njah :D Seekord läksid kõigil ennustused metsa :P
Aga mis puudutab siin uuendusi, siis RudiTurbo vahepeal rääkis et peaks ennustused saatma PM-iga Nimhile, sest muidu paneb alati minu ennustuse kanti enda ennustuse ka ja ma ei saagi järgi (need on tema enda sõnad :P):D
Tegin katste:P :
panin aja kirja, siis muutsin, vaatan -- ruddika ennustus ka muutus :D.ok, muutsin 1 minut enne starti ja Rudika ennustus ka muutus minu omale sarnasemaks :D :D. ei tea, äkki oli juhus, aga tobenaljakas ikka :)
Go Markko and Michael !!! :D
To nimh:Kui sellise süsteemiga ennustus käima lükata tuleval aastal,siis kuidas hooaja kokkuvõttes kõigi etappide peale punktide liitmine käiks?
F1 ekspert
F1 ekspert
Postitus Postitas RudiTurbo »
Hehe, ei see etapp oli nii, et ei järginud sinu ennustust, sest teadsin, et 1.41 nad ei sõida ja kui ma olin endal viimased 1.42 ennustused ära teinud, siis avastasin, et sa ka seal tegemas viimase minuti muudatusi, ma lihtsalt ei suutnud otsustada :D
Aga nii ma jah ütlsein ja PM-i teel oleks põnevam :)
Postitus Postitas quattro »
Krt rada oli muudetud peale 2002a GP-d, sellepärast ka ajad sellised :shock: kahju, et ennem seda ei teadnud :(
Parem sõita, kui kahetseda...
mrali kirjutas:To nimh:Kui sellise süsteemiga ennustus käima lükata tuleval aastal,siis kuidas hooaja kokkuvõttes kõigi etappide peale punktide liitmine käiks?
Meil on kaks võimalust.
Esiteks; kas liidame etappide ajad kokku ning üldvõitjaks tuleb see, kelle aeg on väikseim.
Teiseks; kas anname iga etapi parematele mingisuguse punktitabeli järgi punkte, võitja oleks see, kel punktide arv suurim.
Esimene variant oleks parem ma arvan. Aga liita ei saa sest kui ma osa ei võta siis saan nulli ja lähen liidriks. :D Võiks hakata aegu mingist ajast lahutama. Nt. 40 sekundit. Kellel hooaja lõpuks kõige väiksem aeg on, on võidumees. :)
Postitus Postitas kosmonaut »
see uus süsteem meeldib:). PM - iga on jah parem saata ennustused, sest ise ka vaatan siin teiste aegu. seekord oli kindel mõte panna umbes 1.45.1 aeg. aga jah. nii ta läks. uue süsteemi punktiarvestus oleks hea nii nagu erki ütles et suvalisest ajast lahutada maha.
Postitus Postitas Karmen »
Erki kirjutas:Nüüd oleks siis õige aeg öelda et mina mõtlesin välja kakukese ennustuse. :D
:rainbowafro: no ma tänan :D
F1 ekspert
F1 ekspert
Mingit reeglite muudatust ei ole vaja nagu poole hooaja pealt nüüd või lisareegeleid punktisüsteemi osas.
Järgmine hooaeg tuleb ennustused saata jah PM-ga siis on võimalus ka liider kätte sada. Muidu on jälitaja jaoks asi võimatu.
RudiTurbo kirjutas:Mingit reeglite muudatust ei ole vaja nagu poole hooaja pealt nüüd või lisareegeleid punktisüsteemi osas.
Kogu süsteemi muudame ära ja teeme uued reeglid. :lol:
Mängime nüüd telemängu nimega FIA siin foorumis :lol:
Muidugi kui ennustused saadetakse PM-ga teeb see tööd Nimhile juurde. Sest kõik ennustused tuleb tal ka siia peale sõitu ülesse panna kõigile näha. Aga see PM-ga saatmine on hea idee. See annab kõigile võrtsed võimalused.
Mõtlesin, et kui etapp vahele jääb, võib määrata ajaks võistluste aeglaseima kiireima ringi + 5 trahvisekundit.
Aga ilmselt on parimaks lahenduseks punktisüsteemi kehtestamine hooaja järjestuseks. Siis jääks ära ka üksteise passimine. Mul pole mingit tahtmist PM-dega jamada.
10-8-6-5-4-3-2-1 sobib?
nimh kirjutas:Mõtlesin, et kui etapp vahele jääb, võib määrata ajaks võistluste aeglaseima kiireima ringi + 5 trahvisekundit.
Selline varjant on kah väga hea. Vastavalt tulemustele saad punktid. Aga see ükseise passimine jääb ikkagi. Kui sul just mingit väga head ideed ei ole kuda neid punkte jagada.
Jaanus, Erki, Frank, mrali, RudiTurbo, nimh
