Mehhiko Ralli III päev
Rasmus
Postitus Postitas Rasmus »
Viimase päeva ajakava:
Teenindus F (León)
SS 13 Comanjilla - Chichimequillas 18,26km 17:17
SS 14 Alfaro - El Establo 44,39km 18:25
Teenindus G (León)
Praegune seis:
1 SOLBERG 0.0
2 GRÖNHOLM +29.6
3 MÄRTIN +1:23.9
4 GARDEMEISTER +4:11.5
5 ROVANPERÄ +4:12.9
6 LOEB +4:48.9
7 WARMBOLD +5:20.3
8 PANIZZI +5:44.9
9 SCHWARZ +6:44.5
10 SOLA +13:31.3
Muutust on oodata kohtadel 4-6, kuid viimane pikk katse võib nii mõndagi veel muuta, tehniliste probleemide eest ei ole keegi kaitstud.
Splitid
Raadio
Subaru
Mitsubishi
Erkki
Postitus Postitas Erkki »
Ega ka Panizzi võib ju ka väga vabalt Warmboldist mööduda
ott
Postitus Postitas ott »
leg2 kokkuvõta peugeoti kohta
Peugeot
On the first loop of stages, the Peugeot drivers underlined their strong performance on the opening leg. Marcus Gronholm closed to within 16 seconds of the leader Petter Solberg by setting fastest time on SS8.
This stage featured a tough uphill climb, which peaked at a summit of 2500 metres – proving the strength and power of the Peugeot 307 WRC's engine. Markko Martin go the better of his battle with Citroen driver Francois Duval, pulling out an advantage of 24 seconds. On the second loop of stages the Peugeot drivers consolidated their positions, mindful of team orders to get to the finish at all costs.
Marcus Gronhölm / Timo Rautiainen: "In order to solve our recurring brake problems, the team asked us to change brake pads after every stage – so this has been quite a busy day for me! Nonetheless, this solution worked well, and today I felt a lot more confident than I did on the opening leg. This rally has been a lot trickier than it was last year, as the surfaces are so much harder which **** a bigger demand on the car. I think everybody has had a few problems today, so to still be here is the main thing. Tomorrow my plan is to consolidate my second place and hopefully we can finish with two cars on the podium."
Markko Martin/Michael Park: "We did not have as many brake problems as Marcus, so we were not changing the pads after every stage. We had to keep an eye on Francois Duval, but after he retired the pressure was off us. We will be very happy to finish third tomorrow – there's no way we can challenge Marcus and there is not a big threat from behind. But we still have to keep concentrated – there is a long way to go and the last stage, which is 44 kilometres long, will be very tough."
Väike parandus. Kuna Sola auto sai liiga palju kannatada, siis ta täna ei stardi ja 10 kohal on tegelikult JWRC liider Guy Wilks.
Sola auto oli päris korralikult üle käinud.
Atkinson lõhkus roolivõimu täpselt samal hüppel, kus eelmine aasta Loeb Xsara karteri puruks hüppas.
lenc
Postitus Postitas lenc »
veteran
Postitus Postitas veteran »
Eilse päeva lõpu pressikonverents:
End of Leg 2 Press Conference
(12/3/2005 8:00:00 PM)
Saturday March 12th 2005
ATTENDEES
1. Petter Solberg Subaru World Rally Team
2. Marcus Grönholm Peugeot Total
3. Markko Märtin Peugeot Total
Q: Markko, in many ways it’s been an action packed day. You’ve managed to stay out of trouble though…
MM:
Yes it’s been OK. No real problems. We tried to keep our position on the first three stages and then all the people behind us disappeared so there was no need to push. We need to make sure we finish.
Q. You said before the rally that you didn’t have a very representative test for this event – there was even some snow. We know that in your team you can’t do much in the way of suspension changes; that must be frustrating.
MM:
Yes, it is frustrating, we just have to do the best we can.
Q: Marcus, you’ve been chasing Petter Solberg all day but you seem to have had brake problems throughout.
MG:
Yes, I’ve changed the brake pads after every stage. We’re fitting different brakes for tomorrow but we’re going to have to settle for second.
Q: We always see you as a typical Finn on maximum attack but you need points tomorrow so will you be taking things carefully?
MG:
Yes, I need the points to still be here for the title fight. :?
Q: A question for Petter Solberg. Petter, this is your second day as rally leader. Have you been surprised by the retirements and the action?
PS:
We saw on the recce that the first day was like tarmac but the second day was rough, so last night we set up the car for safety and raised it a bit. The stages are very tricky and it’s very easy to hit rocks. If you’re going at 100% it can happen. We’ve been quite cautious and not taken any big risks.
Q: Do you really think Marcus Gronholm will let you win tomorrow. Can you really trust him that much?
PS:
Marcus Gronholm is a man that I trust very much! :lol: (Laughing:) There is no bullshit and no lies with Marcus, just like everyone else in this business!
veteran
Ilmaolud:
Leon, Gto
12°C
Mostly Cloudy
Feels Like 12°C
Humidity:67%
Visibility:12.9 km
Niisiis kohe kohe paks hakkama eelviimane katse
Läks käima Paasonen ja Atkinson on rajal
veteran
Paasonen ja Atkinson juba teel
veteran kirjutas:Ilmaolud:
Leon, Gto
12°C
Mostly Cloudy
Feels Like 12°C
Humidity:67%
Visibility:12.9 km
Niii jahe. :o Äkki nüüd avaldub ka Markko+Peugeot võimed, testiti ju Itaalias ka suht jahedates oludes.
Duval kah startis
Unine
Postitus Postitas Unine »
Ega need võimed puhta sõiduga üle 3 koha siiski ei vii aga katsevõit või kaks oleks küll hea :)
veteran
Erki kirjutas:
Leon, Gto
12°C
Mostly Cloudy
Feels Like 12°C
Humidity:67%
Visibility:12.9 km
Arvan et see on praegu,hommikul. Päeva peale lubab seal 26C väheste vihmasagaratega
veteran
Atkinson allahindlust kiiruses juba ei tee
eix
Postitus Postitas eix »
Atkinsonilt tuleb hea aeg.
atkinson teeb väga korralikku tempot
quattro
Postitus Postitas quattro »
kas ainult üks split ongi sellel katsel?
Parem sõita, kui kahetseda...
veteran
See tuleb üks küüntenärimise katse - on ainult 1 splitikoht 4,5km kohal.
Ülejäänud 14 km kohta ei tule enne infot kui finishis.
