Tere !
Müüa siis VAZ 21063 1.9 R4 134KW .
Varustus : Country: Estonia; Production date: 1991/2013; Transmission: 5 speed Dog-box; Weight: 850kg; Wheel side: Left; Class: E and historic; Shock absorbers: Bilstein; Power: 134kw/ 180hp; 1949 ccm engine; Niva block; VFTS camsaft and valve; Double 45mm Italy Weber; Electric low pressure fuel pump; 4-2- 1 Martelius exhaust; 5 speed dog box; 5.13 final drive with Limited- slip differental ( original russian 6 rings ); Steel flywheel with ceramic clutch; 4x disk brakes; Ferodo racing brake pads and Brembo brake disk; FIA homologitation steel rollcage; Hydraulik handbrake; Adjustable brake valve; Sparco steering wheel; Schroth racing belts; Sparco seats;
Kuulutus ka aadressi http://www.auto24.ee/used/1234797
