No kas saab üks päev kehvemini alata. Mingi tobeduse pärast rajalt maha võtta.
Vaata newsflash wrc.com-s.Peale seda pole teda ka ju enam paremusjärjestuses. Tehn. kontrollida arvates oli see -
Officials have said this was an unauthorised modification of the car's weight and therefore excluded Martin from the event. He was lying in fourth place before his exclusion.
Kari mölakaid,muud ei tule kohe pähe öelda.
Statistik
See avastati auto kaalumisel eile õhtul peale II päeva.Teoreetiliselt on neil ju õigus - kivi kaalus 5-6 kilo ja ilmselt tõstis auto kaalu üle miinimumpiiri. Tegelikult,kui see rihm oli tõesti katki,oleks pidanud mehaanikud kas või lisaraskuse peale panema,ilmselt hoiti auto kaalu ikkagi alla piiri. Muidugi pole siin kriipsugi MM süüd,aga mehaanikuid ju maha võtta ei saa.
Statistik
Hea et see kõik unenägu on(:
Päris nii see ka polnud negu arvasin.Auto kaalus ikkagi 1253 kg, minimaalne on 1230 kg. Seda kivi vaadeldi kui "lubamatut auto kaalu muutmist" ja mehaanikutel polnud asjaga pistmist. Kivi panid nad ise autosse kui ratast vahetasid ,kuna tagavararatta kinnituse rihm oli purunenud.
Markko Martin's Ford Focus was excluded from Rally Australia by the Stewards of the meeting last night for infringing Appendix J Art. 252 2.2.
It appears that a rock weighing five or six kilos was found within the car and that this contributed to the car's weight when weighed. This amounted to an unauthorised modification of the vehicle's weight.
The rock had been placed in the car by Martin and co-driver Park when they stopped to change a wheel during yesterday afternoon. The ratchet mechanism holding the spare wheel in place failed and they used the rock to wedge the spare wheel in place so that they could continue. Scrutineers spotted the rock when the car arrived at service and reported the matter. The car was weighed at 1253 kg; the minimum weight allowed is 1230kg.
Aga ikkagi seakari
Aga ikkagi seakari
Statistik
Ega ma maksimukaalust rääkinudki. Esialgu arvasin,et ta auto kaalus tegelikult alla vähima lubatud piiri ja ta kasutas seda kivikiilu ,et kaal oleks ikkagi rohkem kui miinimum. Aga tegelikult oli tal isegi 23 kg varu veel. Ma oleks veel aru saanud,kui mahavõtmise põhjuseks oleks ohutus - näiteks kivi pääseb lendama kui autot kantima hakkab, aga LUBAMATU AUTO KAALU MUUTMINE - see on küll erakordselt nõme põhjus. Häda ju ajas härja kaevu - ratas peab kinni olema. Põrgusse.tommi kirjutas:Sellest ma saan veelvähem aru, mumeelest pole autodel maksimumkaalu vaid miinimumkaal
